Resinman
#1 Posted : Wednesday, March 25, 2009 1:25:04 PM(UTC)
Resinman
Freezer started to get warm measured at 46F, cleaned coils under unit of dust lint ect, unplugged to reset, unit went down to 36F. I thought it was fixed next day unit was not cooling at all, removed food, ran diagnostic check control panel "bargraph", checked ok. Removed panel in back of freezer no ice on coils, coils warm, all fans running and compressor cycling but cycles are short, condensor is hot to touch. All copper tubes in or out of compressor warm.
Need help?
woodchuckie
#2 Posted : Wednesday, March 25, 2009 1:44:01 PM(UTC)
woodchuckie
Resinman
#3 Posted : Wednesday, March 25, 2009 3:32:22 PM(UTC)
Resinman
Originally Posted by: woodchuckie Go to Quoted Post
How short are the cycles. Could be a compressor relay/overload switch.
Part 13 on this diagram of your unit. http://http://www.searspartsdir...0Sub%20Components%20list
Cycles are real short 10 seconds, or thereabouts
Resinman
#4 Posted : Wednesday, March 25, 2009 3:38:08 PM(UTC)
Resinman
Can I test that>
woodchuckie
#5 Posted : Wednesday, March 25, 2009 4:04:15 PM(UTC)
woodchuckie
With that short of a cycle the relay will be the problem. Take it off see if it rattles.
Resinman
#6 Posted : Wednesday, March 25, 2009 5:06:55 PM(UTC)
Resinman
The overload and start relay are in a case, having trouble getting both out of the case. I see you can order them together, their is definetly a rattle, and debrie (dark brown particles like coffee) coming out of the assembly but not sure if the other component rattles
Resinman
#7 Posted : Wednesday, March 25, 2009 5:09:43 PM(UTC)
Resinman
Actually not in a case but fit together after further inspection
