please help! looking for the outer glass oven door in black and everywhere im being told there are no longer in stock what can i do to replace the oven glass door? :(
Unfortunately this part has been discontinued by the manufacturer and is no longer available.
I would measure the glass size and where the window is located in the glass, a diagram may help. Then go to several appliance retailers and measure the glass/window on new units. You may be able to find one that is the same glass dimensions with a window that is close to yours. Then get the Model Number and order that glass.
If you cannot find a replacement, you may be out shopping for a new unit so might as well see how lucky you are. |
THIS FORUM IS DEAD!!!!!!! |
