rycin
#1 Posted : Wednesday, March 25, 2009 6:12:20 AM(UTC)
rycin
please help! looking for the outer glass oven door in black and everywhere im being told there are no longer in stock what can i do to replace the oven glass door? :(
#2 Posted : Wednesday, March 25, 2009 5:10:00 PM(UTC)
Unfortunately this part has been discontinued by the manufacturer and is no longer available.
#3 Posted : Thursday, March 26, 2009 1:47:47 AM(UTC)
I would measure the glass size and where the window is located in the glass, a diagram may help.
Then go to several appliance retailers and measure the glass/window on new units. You may be able to find one that is the same glass dimensions with a window that is close to yours.
Then get the Model Number and order that glass.
If you cannot find a replacement, you may be out shopping for a new unit so might as well see how lucky you are.
Viking Oven door opens only 1/2 in. Did not use self -clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 1:50:17 PM(UTC)
Oven door almost opens (Oven Repair (including Ranges and Cooktops))
by hasyed 3/30/2023 1:13:59 PM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
Frigidaire GLGFS66.ABB Oven Door Sticks at Broil Stop Position (Oven Repair (including Ranges and Cooktops))
by gdaarob 3/28/2022 6:15:15 AM(UTC)
Jennaire JGS8860BDP oven door (Oven Repair (including Ranges and Cooktops))
by df911 11/4/2021 9:38:06 AM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Oven Door Locked - No Power (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 10/26/2020 3:33:54 PM(UTC)
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Kitchenaid wall oven door locked (Oven Repair (including Ranges and Cooktops))
by mdawley 3/6/2020 9:40:01 AM(UTC)
Whirlpool Wall Oven Door Locked and No Power (Oven Repair (including Ranges and Cooktops))
by sunia 11/14/2019 7:10:53 AM(UTC)
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
Replace oven door assembly or outer tempered glass (Oven Repair (including Ranges and Cooktops))
by Jkaup 6/15/2019 8:29:47 AM(UTC)
Oven Door still will not close after hinge and seal replacement (Oven Repair (including Ranges and Cooktops))
by Ten13 3/18/2019 8:45:03 AM(UTC)
