kjeg
#1 Posted : Wednesday, May 9, 2012 12:23:08 PM(UTC)
kjeg
I have no idea how old this DW is. It worked great. The lights on the lefthand side starting with soak and scrub to the High temp wash in the middle of the panel, work. The lights on the righthand side starting at the middle with enery saver dry to the cancel button do not work. Above that is a water heating light and a child lock light. Those lights do not work either. My grandkids were here the same day....I don't know if they pushed something or if it's a coincident. I ck'd the float as well, and I turned DW off at the breaker, waited 30 seconds then flipped the breaker back on. It still wont start. Any Ideas?? Thank you in advance for any help you can give me!!! Sincerely, Karen ;(
Simon / APP Team
#2 Posted : Wednesday, May 9, 2012 1:11:59 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is bad control panel.
But before getting a new one remove the panel, disconnect the flex ribbon connector to the control board.
Using the pencil eraser clean the contacts at the end of the ribbon. Plug it in and check if that will fix the problem.
If not - get a new control panel Part number: 9744101
Here are the breakdown diagrams and Replacement parts for Whirlpool KUDG25SHBT1 DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
kjeg
#3 Posted : Thursday, May 10, 2012 11:38:44 AM(UTC)
kjeg
:) I'll let you know how it turns out!! Thank you!! Have a great day!!
Karen
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
