paul929
#1 Posted : Saturday, May 5, 2012 11:46:04 AM(UTC)
paul929
my microwave timer works and is lit up inside but doesn't actually heat up. when it first started doing it i could lift up on the door and it would come on so slightly adjusted hinges and it was working for a short while but now it wont work again. seems to me it could be where the door hooks close in the microwave but not sure. any other possible remedys?
paul929
#2 Posted : Tuesday, May 8, 2012 2:19:35 PM(UTC)
paul929
hey chris thanks for replying, i guess i wasn't clear enough on what's happening with it. there is no sound and inside it doesn't rotate so that part of it doesn't work but the light comes on and the timer counts down. and like i said,at one point i could lift up on the door while it was closed and it would come on and heat so I'm thinking it's in one or both relays where the door hooks connect in the microwave.
paul929
#3 Posted : Wednesday, May 9, 2012 4:34:34 AM(UTC)
paul929
thanks chris that's exactly the way i was leaning. i'm gonna bypass the door sensor and see if it works. and thanks for the info on the cost of the other parts cuz if its one of those i'll now know to just replace it. thanks again,paul
Guest (4)
Microwave fuse blows out frequently (Microwave Repair)
by Guest 6/15/2024 4:55:42 AM(UTC)
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Microwave goes dead when hot (Microwave Repair)
by Guest 5/5/2024 8:05:15 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
