2 Pages12>
Wesley0423
#1 Posted : Friday, April 27, 2012 3:42:48 PM(UTC)
Wesley0423
The refrigerator is not cooling and freezing. I checked the compressor fan at the back and evaporator fan inside of the freezer compartment, both are working. what problem it could be?
#2 Posted : Saturday, April 28, 2012 12:58:03 AM(UTC)
Check your model #
Wesley0423
#3 Posted : Saturday, April 28, 2012 8:24:55 AM(UTC)
Wesley0423
thanks very much for your reply.
Model Number: HSM25GFTSA Brand: Hotpoint Age: 5 - 10 years
[URL="http://forum.appliancepartspros.com/refrigerator-freezer-repair/471351-hotpoint-refrigerator-neither-cooling-nor-freezing.html#ixzz1tLtYRGYi"][/URL]what I got
When I plugout and plugin the power, I heard a kick sound, I believe that is the compressor starting. Since that i see both fans keep running for about hours, all of sudden everything stopped. The light is still on when I open the door. during the whole process, I can only feel normal temperatures wind coming from the fan, never freezing or cooling. No kick anymore since the first one.
#4 Posted : Saturday, April 28, 2012 3:15:35 PM(UTC)
Sorry for the delay, I never got an email, don't know if it's this site or gmail problem.
Most probable problem is the motherboard in the back, bad solder joints, AP4436216.
To confirm, pull off the three pin, gray power connector from the motherboard and stick a jumper wire between the connector mating pins labeled line and comp as labeled on the motherboard. Plug in fridg, if compressor starts, that confirms it.
Wesley0423
#5 Posted : Saturday, April 28, 2012 3:46:13 PM(UTC)
Wesley0423
Thanks for your help and I'm gonna give it a shot and keep you updated
Wesley0423
#6 Posted : Sunday, April 29, 2012 1:09:34 AM(UTC)
Wesley0423
Hi richappy, I haven't tried the motherboard yet, however I tested the thermostat resistance. I found the resistance always keep 0 no matter I tested in air temperature or ice temperature, does this mean the thermostat fail and I need get it replaced?
#7 Posted : Sunday, April 29, 2012 5:29:18 AM(UTC)
If you are measuring the defrost thermostat, that opens up at temperatures way over ambient, like over 100 degrees.
Wesley0423
#8 Posted : Sunday, April 29, 2012 11:24:55 AM(UTC)
Wesley0423
Yes, I'm measuring the defrost thermostat, I tested it in hot water that temperature over 100 degrees, the resistance is still 0. do you think this could be the reason? in my observation, the evaporator fan always blow out air of room temperature.
#9 Posted : Monday, April 30, 2012 1:05:54 AM(UTC)
Check the compressor in the back. If the fan is ruuning, but compressor cold, you have a bad motherboard.
Wesley0423
#10 Posted : Wednesday, May 2, 2012 12:34:08 AM(UTC)
Wesley0423
Sorry for late update, too busy on other stuff. I checked again, when I plugged in the power, only the refrigerator defrost heater started. a couple of minutes later, the defrost heater stopped and it was warm in the freezer. Then the evaporator fan and compressor fan started, I touched the compressor, it's vibrating, but the compressor never gets hot. Is this caused by bad motherboard? Is AP4436216 the right part I'm looking for?
As the defrost thermostat always has 0 resistance no matter hot or cold, is it broken too?
Guest (5)
2 Pages12>
