genedyer@hotmail.com
#1 Posted : Saturday, April 21, 2012 4:50:51 AM(UTC)
I have a 6 year old kenmore dishwasher.It fills with water and then drains
#2 Posted : Saturday, April 21, 2012 5:00:31 AM(UTC)
my kenmore dishwasher fills up and then drains.It does nothing else.any ideas what to look for?
#3 Posted : Saturday, April 21, 2012 5:35:03 AM(UTC)
A model number may help others help you.
#4 Posted : Saturday, April 21, 2012 5:46:51 AM(UTC)
the manual says 665.1367,on the inside of door it says 13679k600
#5 Posted : Saturday, April 21, 2012 6:23:08 AM(UTC)
having a hard time using this site
#6 Posted : Saturday, April 21, 2012 6:27:16 AM(UTC)
having a hard time useing this site.
#7 Posted : Sunday, April 22, 2012 3:22:58 AM(UTC)
Replacement parts for Kenmore 66513679K600 | AppliancePartsPros.com
The Sears site does have part breakdown diagrams, just search for your model using 665.13679K600.
They like to keep the diagrams to themselves.
Here is a manual which may apply.
there is not a cross reference from Sears to the actual manufacturer (in this case Whirlpool) os I have to guess. The link is fora unit that uses the same control board.
http://appliancejunk.com...&id=229;t=1335092855
You may have to join the site to get the manual.
Try different cycle to see if this always happens.
Check for any error code indications.
Is it filling and then emptying or emptying while filling?
Open up and clean the main pump.
habitat for humanity
#8 Posted : Saturday, July 28, 2012 6:03:29 AM(UTC)
totally shut the unit down (turn of circuit breaker) let it power down then restart the unit to see if it will start up. You did not mention if it was digital control panel or not. also your diverter valve that allows the dirty water to drain after washing may be stuck open.
kenmore dishwasher 66513043K116 still not draining, after changing drain motor? (Dishwasher Repair)
by thivakaran 12/5/2022 11:47:06 AM(UTC)
Repeating Error 24 on Kenmore Dishwasher (Dishwasher Repair)
by abidh2 12/24/2021 4:45:12 PM(UTC)
Kenmore Dishwasher 665.13733K600 Major Leak Problem (Dishwasher Repair)
by Ken More73 11/10/2021 12:22:29 PM(UTC)
Kenmore Dishwasher - no control lights but washer works (Dishwasher Repair)
by toibn46 10/22/2021 10:08:47 AM(UTC)
Kenmore Dishwasher Keeps Running (Dishwasher Repair)
by VicRattlehead 9/21/2021 1:25:13 PM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Kenmore dishwasher turning on by itself (Dishwasher Repair)
by Guest 5/24/2021 11:06:12 AM(UTC)
Kenmore Dishwasher drain output has stong sulphur smell (Dishwasher Repair)
by Larbo 1/13/2021 3:35:42 PM(UTC)
Kenmore Dishwasher Heater (Dishwasher Repair)
by mikedbom 11/11/2020 4:21:33 PM(UTC)
Kenmore Dishwasher Smartwash (Dishwasher Repair)
by katzman299 1/4/2020 11:02:06 AM(UTC)
Kenmore dishwasher model 665.15113K211 started high pitch sound between cycles (Dishwasher Repair)
by redeyedog 5/10/2019 8:21:48 AM(UTC)
Kenmore Dishwasher control pannel not working (Dishwasher Repair)
by Douglas Scherer 3/14/2019 6:32:33 PM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
How do you install Part W11048936 for a Kenmore Dishwasher (Dishwasher Repair)
by S Hall 3/23/2018 4:46:54 PM(UTC)
Can't loosen impeller part for kenmore dishwasher (Dishwasher Repair)
by rbhall52 9/5/2017 12:04:52 PM(UTC)
