hi voltage is present but no heat. all interlock switches open/close and seem ok. motors run lights are on, timer times outs normally. ne body know how i can check the magnetron?
You can check the magnetron for continuity with a multimeter. You can also check to make sure it's not grounded.
thanks for the reply. what resistance values would i be looking for?
i checked the magnetron filament. it measured .1 ohm. the hi voltage measured 3kV on an analog meter. all suggestions welcome.
