3 Pages123>
spoony
#1 Posted : Tuesday, April 17, 2012 11:27:09 AM(UTC)
spoony
Hi All,
Can any one HELP:
How do you get to the wires on the Temp Sensor to change it or Check it ?
Just pull on the sensor wires ? It is on a GE Profile Arctica
# PSS25NGNA WW can you help.
Thanks,Woodie:p
#2 Posted : Tuesday, April 17, 2012 2:04:46 PM(UTC)
Hi Woodie,
What is wrong with your refrigerator?
Here are the breakdown diagrams and Replacement parts for General Electric PSS25NGNAWW Refrigerator | AppliancePartsPros.com
spoony
#3 Posted : Wednesday, April 18, 2012 6:37:48 AM(UTC)
spoony
Hi Woodie,
Thanks Gene,
The refrigerator will cool to 36 on freezer side and 56 on fresh food side. On the control pad the little red light for the Defrost is on and will not go out with changing temp.and it has ben running for 24 hours straight.
Frost on the back wall of freezer.The fan motor near the compresser run slow but its on.How about the thermostat sensors or defrost heater ?How do you remove them to check.just pull on the wires .
thanks for trying to Help, Woodie:)
#4 Posted : Wednesday, April 18, 2012 12:40:21 PM(UTC)
Hi Woodie,
Unplug the refrigerator. Remove the cover from the main control board on the back of the fridge. Remove the wire from the J9 terminal. Measure the resistance between this wire and the wire connected to the J7-9 pin at the control board. The normal reading suppose to be no less than 22 Ohms.
Unplug the J1 connector and measure the resistance between the wires connected to the J1-4 and J1-5. The normal reading suppose to be (if the temperature inside the freezer is about 36°F) between 12 to 16 K Ohms.
Post the results.
spoony
#5 Posted : Saturday, April 21, 2012 8:31:52 AM(UTC)
spoony
Originally Posted by: spoony Go to Quoted Post
Thanks Gene,
Hi Gene, from Terminal J9 to J7-9 it Reads 25.7 OHMS
AND tERMINAL J1 to J4 and J5 reads 0 OHMS.
Whats next ?:o what do you think
spoony
#6 Posted : Saturday, April 21, 2012 9:29:18 AM(UTC)
spoony
Hi Woodie,
Post the results.Hi Gene, from Terminal J9 to J7-9 it Reads 25.7 OHMS
Whats next ?UserPostedImage what do you think Ihave no Idea temp.Sensers?
spoony
#7 Posted : Sunday, April 22, 2012 6:11:27 AM(UTC)
spoony
Whats next ? what do you think I have no Idea temp.Sensers?
thanks for trying to Help, Woodie.Can it be in Defrost mode maybe?
Read more: http://forum.appliancepartspros...ensor.html#ixzz1smIIJ5sf
http://forum.appliancepartspros.com
spoony
#8 Posted : Sunday, April 22, 2012 6:12:47 AM(UTC)
spoony
#9 Posted : Monday, April 23, 2012 1:26:32 PM(UTC)
...from Terminal J9 to J7-9 it Reads 25.7 OHMS
AND tERMINAL J1 to J4 and J5 reads 0 OHMS.[URL="http://forum.appliancepartspros.com"][/URL]
There is nothing wrong with the defrost heater and the overtemperature thermostat.
On what scale did you set the ohmmeter when you measured the sensor resistance between the J1-4 & J1-5?
spoony
#10 Posted : Tuesday, April 24, 2012 6:37:53 AM(UTC)
spoony
Hi Gene,
Set on 200 scale and it has been run about 4 days straight and the fan motor near the compresser is turning slow.How about freon R134 ? Also did a control diagnostics test with the COLDER/WARMER pads and all looked good.
What NEXTS Thanks, Woodie
Guest (4)
3 Pages123>
