| » Change Temperature sensor |
Model Number: PSS25NGNA WW Brand: GE Age: 5 - 10 years
Hi All,
Can any one HELP: How do you get to the wires on the Temp Sensor to change it or Check it ? Just pull on the sensor wires ? It is on a GE Profile Arctica # PSS25NGNA WW can you help. Thanks,Woodie Ads By Google Related Models |
Hi Woodie,
What is wrong with your refrigerator? Here are the breakdown diagrams and Replacement parts for General Electric PSS25NGNAWW Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks Gene, The refrigerator will cool to 36 on freezer side and 56 on fresh food side. On the control pad the little red light for the Defrost is on and will not go out with changing temp.and it has ben running for 24 hours straight. Frost on the back wall of freezer.The fan motor near the compresser run slow but its on.How about the thermostat sensors or defrost heater ?How do you remove them to check.just pull on the wires . thanks for trying to Help, Woodie |
Hi Woodie,
Unplug the refrigerator. Remove the cover from the main control board on the back of the fridge. Remove the wire from the J9 terminal. Measure the resistance between this wire and the wire connected to the J7-9 pin at the control board. The normal reading suppose to be no less than 22 Ohms. Unplug the J1 connector and measure the resistance between the wires connected to the J1-4 and J1-5. The normal reading suppose to be (if the temperature inside the freezer is about 36°F) between 12 to 16 K Ohms. Post the results. Gene.
__________________
[quote=spoony;726509]Thanks Gene,
The refrigerator will cool to 36 on freezer side and 56 on fresh food side. On the control pad the little red light for the Defrost is on and will not go out with changing temp.and it has ben running for 24 hours straight. Frost on the back wall of freezer.The fan motor near the compresser run slow but its on.How about the thermostat sensors or defrost heater ?How do you remove them to check.just pull on the wires . Hi Gene, from Terminal J9 to J7-9 it Reads 25.7 OHMS AND tERMINAL J1 to J4 and J5 reads 0 OHMS. Whats next ? thanks for trying to Help, Woodie |
[quote=Gene;726730]Hi Woodie,
Unplug the refrigerator. Remove the cover from the main control board on the back of the fridge. Remove the wire from the J9 terminal. Measure the resistance between this wire and the wire connected to the J7-9 pin at the control board. The normal reading suppose to be no less than 22 Ohms. Unplug the J1 connector and measure the resistance between the wires connected to the J1-4 and J1-5. The normal reading suppose to be (if the temperature inside the freezer is about 36°F) between 12 to 16 K Ohms. Post the results.Hi Gene, from Terminal J9 to J7-9 it Reads 25.7 OHMS AND tERMINAL J1 to J4 and J5 reads 0 OHMS. Whats next ? thanks for trying to Help, Woodie |
AND tERMINAL J1 to J4 and J5 reads 0 OHMS. Whats next ? what do you think I have no Idea temp.Sensers? thanks for trying to Help, Woodie.Can it be in Defrost mode maybe? Read more: Change Temperature sensor http://forum.appliancepartspros.com |
Quote:
On what scale did you set the ohmmeter when you measured the sensor resistance between the J1-4 & J1-5? Gene.
__________________
Quote:
Hi Gene, Set on 200 scale and it has been run about 4 days straight and the fan motor near the compresser is turning slow.How about freon R134 ? Also did a control diagnostics test with the COLDER/WARMER pads and all looked good. What NEXTS Thanks, Woodie |
| Display Modes | |
| Can not change temperature | whenders | Refrigerator & Freezer Repair | 0 | 05-26-2011 08:26 PM |
| How to change a moisture sensor? | willycat | Dryer Repair | 0 | 12-26-2010 03:29 PM |
| Temperature Sensor | mrob | Oven Repair (including Ranges and Cooktops) | 1 | 09-07-2010 03:27 AM |
| how to change a bad electric oven heat sensor | garryusbonds | Oven Repair (including Ranges and Cooktops) | 0 | 12-15-2009 08:52 AM |
| Temperature Sensor | ARTYSMARTY2 | Refrigerator & Freezer Repair | 0 | 12-14-2009 11:56 AM |
