jerry388
#1 Posted : Saturday, April 14, 2012 5:08:37 PM(UTC)
jerry388
how do you gain access to replace belt?
#2 Posted : Monday, April 16, 2012 3:36:35 AM(UTC)
Here is the parts breakdown
Replacement parts for Maytag LSE1000 STACKED LAUNDRY- ELE | AppliancePartsPros.com
Here is a manual which I think applies to your unit.
I am not sure as I cannot download from the site right now.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=68
You may have to join the site to download the manual but it is free.
Also if my link does not take you to the manual it is in the "Downloads" section, " Service Repair Manuals for stacked washer/dryer", "16000416 Maytag Stacked Washer Dryer S1000 Models Service Repair Manual"
I would not order parts till you open it up.
You may as well give it a bit of an overhaul .
Check the rear support rollers and the belt idler wheel for bearing slop and wear.
Check the front drum support glides.
Check all internal seals and the drum seals.
Give the interior a good cleaning including the blower wheel.
Also a good time to check/clean your vent system.
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
Belt replacement (Washer Repair)
by mgbwcw64 2/7/2015 9:24:59 AM(UTC)
WED7500VW belt replacement (no belt tensioner) (Dryer Repair)
by dafoster78 5/12/2014 1:56:12 PM(UTC)
Kenmore HE5 screeching sound...belt replacement/idler pulley or both? (Dryer Repair)
by kaikapoo 9/7/2013 5:56:19 PM(UTC)
Belt replacement help (Dryer Repair)
by applianceissues 3/11/2013 8:38:32 AM(UTC)
by garygordon 8/16/2012 7:43:56 AM(UTC)
Drive Belt Replacement (Washer Repair)
by mzulkoski 6/27/2012 12:49:20 PM(UTC)
Belt replacement (Dryer Repair)
by franpugh8767@hotmail.com 6/13/2012 9:14:24 AM(UTC)
WASHER belt replacement (Washer Repair)
by texaslonghorn 6/8/2012 8:42:47 PM(UTC)
No ignition after interior clean and belt replacement (Dryer Repair)
by beek56 3/26/2012 6:10:14 PM(UTC)
Dryer Belt Replacement (Dryer Repair)
by John Osgood 3/18/2012 10:25:52 AM(UTC)
Drive Belt Replacement (Dishwasher Repair)
by TerryNi 3/7/2012 1:18:48 PM(UTC)
drive belt replacement (Washer Repair)
by RodE 1/22/2012 1:16:04 PM(UTC)
Washer Belt replacement (Washer Repair)
by spam_warrior 12/29/2011 4:56:13 PM(UTC)
by splacido 9/24/2011 6:52:35 AM(UTC)
