insagt220@aol.com
#1 Posted : Thursday, March 19, 2009 3:36:18 PM(UTC)
insagt220@aol.com
DBXR453ET5WW - GE DRYER - 1997 PURCHASE YEAR
First problem ever with this dryer, just quit heating - it tumbles
1. checked the household main breakers and hit reset
2. check for blockage - removed
I believe the dryer may have overheated - 1st time we have had a blockage as well.
3. still no heat
Q. Is there a fuse in the dryer that can be reset? AP2042565?
Q. What part or parts should I purchase? - A starting point
Here are the parts I think it could be, but I do not know for sure
so I am looking for some expertise, thank you for your help.
AP2042618
AP2042573
AP2042565
AP2619954
Karen Tennyson
#2 Posted : Saturday, March 21, 2009 2:52:17 AM(UTC)
Replacement parts for GE DBXR453ET5WW | AppliancePartsPros.com
You may want to take a look in the control console, they like to hide the wiring diagram there. Trying to find a GE wiring diagram on the internet is difficult.
At the top of the list would be the thermal fuse.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
kayakcrzy
#3 Posted : Saturday, March 21, 2009 5:45:34 AM(UTC)
kayakcrzy
It would not be the thermal fuse. If it was, the dryer would be dead. Just because you hit the reset, does not mean you have full power coming to the dryer. If you do not have a meter, you will be guessing, and it will cost you alot more that way. You need to whip out a volt ohm meter, and check the power coming into the dryer, where the cord goes into the back. If you have 240 volts there, you will most likely have a bad element. But, it would be nice to whip out the ohm meter, and see if the element has continuity. Tom ApplianceEducator.com
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
