zannado
#1 Posted : Wednesday, April 4, 2012 6:16:03 AM(UTC)
zannado
Hello everyone I have a side by side Whirlpool refrigerator that has stopped dispensing water. It is still making ice but when you push outside tab for water you get nothing and hear nothing. I didn't know if is sounded like the water value or something else.When I disconnect the line behind the kick plate there is not water there.Can someone help me??? Thanks
#2 Posted : Wednesday, April 4, 2012 4:01:38 PM(UTC)
Remove the wires from the water inlet valve solenoid (where the 5/16" tube is connected to) and check for 120 VAC between these wires while the water dispenser calls for water.
If the voltage reading is correct, replace the water inlet valve.
If the reading is incorrect, post it and we'll go further.
- The water inlet valve Part number: AP5263471
zannado
#3 Posted : Thursday, April 5, 2012 5:49:49 AM(UTC)
zannado
Here are the breakdown diagrams and Replacement parts for Whirlpool ED5FHEXNS00 REFRIGERATOR | AppliancePartsPros.com
Gene.[/quote
OK. I will have to get a voltage meter and check it then I will let you know. Thanks
Ash151
#4 Posted : Saturday, April 14, 2012 8:19:04 AM(UTC)
Ash151
Gene, there is no reading on the wires on the Valve, what do I do next?
#5 Posted : Saturday, April 14, 2012 11:44:17 AM(UTC)
Remove the dispenser cover and check the water dispenser micro switch at the water dispenser lever. Post the results.
- The micro switch Part number: AP3131893
Ash151
#6 Posted : Tuesday, April 17, 2012 6:02:56 AM(UTC)
Ash151
Seems the bracket holding the Switch has broken, which dislodgbed the Switch. The switch itself works fine.....ordered replacement bracket. :cool:
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Whirlpool Refrigerator WSF26C2EXY02 (Refrigerator & Freezer Repair)
by DLanier 12/4/2023 5:06:34 AM(UTC)
Whirlpool Refrigerator Issue (Refrigerator & Freezer Repair)
by jrbentley 11/5/2023 1:04:02 PM(UTC)
Whirlpool Refrigerator Model WSF26C2EXF01 not making ice. (Refrigerator & Freezer Repair)
by agarcia5 8/26/2023 4:53:02 PM(UTC)
Whirlpool Refrigerator Model ED25TEXHW01 (Refrigerator & Freezer Repair)
by jammer48 8/18/2023 1:05:09 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
Whirlpool Refrigerator making a rather odd noise (Refrigerator & Freezer Repair)
by dbdata 12/7/2022 9:55:57 AM(UTC)
Whirlpool refrigerator water dispensing issue (Refrigerator & Freezer Repair)
by andymayor 7/6/2022 2:22:17 PM(UTC)
Whirlpool refrigerator replacement ice maker (Refrigerator & Freezer Repair)
by MELLIOTT 6/9/2022 9:06:52 AM(UTC)
Whirlpool refrigerator Model Number et1mtkxkq07 (Refrigerator & Freezer Repair)
by Guest 5/13/2022 1:16:28 AM(UTC)
Whirlpool refrigerator won’t freeze (Refrigerator & Freezer Repair)
by Nick72 5/12/2022 7:37:51 AM(UTC)
Whirlpool Refrigerator GD5SHAXLQ02 - Door not dispensing ice (Refrigerator & Freezer Repair)
by z-vap 3/21/2022 5:33:58 AM(UTC)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
