jwdefnall@hotmail.com
#1 Posted : Tuesday, April 3, 2012 3:14:41 PM(UTC)
Hello I have a whirlpool dryer model leq9508pwo. It stoped heating, In testing it I found that the thermal cut off was open. I replaced the thermal cut off, the hi limit thermostat and the dryer cycle thermostat and the heating element was working how i did not work very long, not even one load, now the thermal cut off is open again. can you tell me what may be causing this problem.
#2 Posted : Tuesday, April 3, 2012 6:07:15 PM(UTC)
The first thing I would do is take the dryer apart and clean all air ducts, including the lint chute (#1 on the diagram). The house vent for the dryer must be cleaned as well.
Here are the breakdown diagrams and Replacement parts for Whirlpool LEQ9508PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
#3 Posted : Wednesday, April 4, 2012 2:23:39 AM(UTC)
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
keeps blowing thermal cut off switch (Dryer Repair)
by lburt 4/11/2021 1:03:48 PM(UTC)
can you bypass thermal cut off on whirlpool dryer just until new part comes in (Dryer Repair)
by dbisson 1/18/2015 10:07:59 AM(UTC)
TCO (thermal cut off) for Advantium (Microwave Repair)
by perijon 3/18/2013 11:04:54 AM(UTC)
Recurrent thermal cut off blowing... (Dryer Repair)
by nola mike 12/2/2012 3:28:58 PM(UTC)
Installation of dryer thermal cut off kit (Dryer Repair)
by Pjenkins 1/19/2012 9:47:08 AM(UTC)
Replacing Thermal Cut Off (Dryer Repair)
by tlc01 3/29/2011 2:43:45 PM(UTC)
Kenmore Dryer Thermal Cut Off (Dryer Repair)
by Dhock 1/3/2011 1:06:54 PM(UTC)
thermal cut off (Dryer Repair)
by mitsujoe 2/21/2010 4:53:44 AM(UTC)
thermal cut off blown again (Dryer Repair)
by timm6528 12/21/2009 6:37:27 AM(UTC)
Thermal cut off (Dryer Repair)
by gabe_1981 11/10/2009 5:03:51 PM(UTC)
Quick dryer question........Thermal cut off switch (Dryer Repair)
by daey428 8/29/2008 4:02:25 PM(UTC)
Thermal Cut Off Keeps Breaking (Dryer Repair)
by wbuc 2/28/2008 5:49:05 PM(UTC)
