tlc01
#1 Posted : Tuesday, March 29, 2011 2:43:45 PM(UTC)
tlc01
I just replaced the heating element in my Kenmore Elite dryer and I have the thermal cut off fuse to put back but when I look at pictures of them online it shows 2 wires and mine only has 1 wire is this okay?
#2 Posted : Tuesday, March 29, 2011 6:19:39 PM(UTC)
Any electric part should have at least two terminals and at least one wire connected to each of these terminals. It must be two wires connected to the thermal cut-off fuse.
tlc01
#3 Posted : Saturday, April 9, 2011 6:16:28 AM(UTC)
tlc01
I have replaced both the heating element and the thermal cut off fuse but I still have no heat. What else could be wrong?
#4 Posted : Monday, April 11, 2011 4:33:04 PM(UTC)
Have you tested these parts prior to replace them?
Guessing is the most expensive way to fix anything.
You have to have a simple multimeter to perform the troubleshooting. Let us know when you ready and we will guide you through that process.
