I have a 6 year old Whirlpool Electric Dryer. The model number for my Whirlpool Electric Dryer is GEW9200LW1 When I select any of the dryer settings on the touchpad, the appropriate lights light up and the time display also shows the correct amount of time (so all is well at this point). However, when I push the start button, all I get is a click and it doesn't start. The Sensing light does flash as if the dryer would actually be working, and sensing the wetness of the clothing, but nothing else happens. Then, when I push the Pause/Cancel button, I hear the click again, as if the dryer would be stopping itself as it should. Pressing the Pause/Cancel button once more and it shuts off completely, again, as it should. The belt is fine, lights are working, etc....help!! Becca
THIS FORUM IS DEAD!!!!!!! |
