whilburn
#1 Posted : Monday, March 16, 2009 12:52:53 PM(UTC)
whilburn
The agitator will not agitate or spin at all (I know its not the door switch and it is pumping the water out of the drum.
I read that some machines have a reverse function with the motor to agitate, is this the case with this machine?
Also, the agitator will not spin, at all, either direction, by hand; is this indicative of anything?
I realize that it could be the water level switch, but at the beginning of the cycle, the water does fill up and shut off; at this point, I should have agitation.
I can spin the drum within the outer plastic bowl in both directions, but am not exactly sure the total process.
any help appreciated.
Wayne
#2 Posted : Tuesday, March 17, 2009 6:39:08 PM(UTC)
Wayne,
If the motor does run during the agitation and spin then the problem most likely is a broken motor drive coupling (#13 on the diagram)
- The part number for the coupling is AP3963893
You have to remove the washer cabinet to access the part. The complete instruction attached.
File Attachment(s):
How to replace the motor drive coupling.doc (25kb) downloaded 13 time(s).
How to remove the washer cabinet.doc (25kb) downloaded 9 time(s).
How to remove the pump.doc (25kb) downloaded 7 time(s).
whilburn
#3 Posted : Tuesday, March 17, 2009 6:53:18 PM(UTC)
whilburn
Thanks for your reply Gene.
Today, I eased the unit over and started inspecting the coupling. On first look, the coupling looked ok, but I noticed debris all over the frame surrounding the coupling and then I tried to spin the coupling, it was loose as a goose. After I removed the coupling, I was able to spin the agitator which backfeeds the gear box and it spun freely. I went to a hardware store, replaced the coupling and so far, it has washed about 5 loads of clothes.
I appreciate this forum and the people who are generous with their trade knowledge.
Wayne Hilburn
#4 Posted : Tuesday, March 17, 2009 6:59:24 PM(UTC)
You are welcome. We are glad you were able to fix it.
