rick.g
#1 Posted : Sunday, March 15, 2009 7:37:09 AM(UTC)
rick.g
first i had water pouring from the icemaker. i replaced the solenoid valve
assm. ice made once and water again poured from the icemaker. i have replaced the icemaker with a new one. it has been hooked up for 28 hrs and has not worked yet. i have turned the controls up and checked to make sure all connection to the icemaker are tight. ( the icemaker is a whirlpool ). is there any thing else i need to check for? will the icemaker still cycle if if it is a water problem?
woodchuckie
#2 Posted : Sunday, March 15, 2009 9:38:55 AM(UTC)
woodchuckie
Try filling the ice tray manually and see if it starts cycling after it freezes and dumps the ice.
rick.g
#3 Posted : Wednesday, March 18, 2009 7:21:38 AM(UTC)
rick.g
I tryed that with no luck. when I replaced the icemaker I had to unhook the power supply at the ice maker itself. I installed the new icemaker using the same power supply hookup. the black wire has a plastic clip on it that attaches to the side of the ice tray. Is that some type of inline fuse or power switch. I have used a test light at the end of the plug that hooks to the icemaker to check for power, I show no power between the black and white wire.
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
