margsain
#1 Posted : Sunday, November 25, 2007 11:38:57 AM(UTC)
margsain
Washer tub makes a rubbing sound when agitating. It seems to work fine on light loads, but makes a rubbing sound like the tub is sitting on something rubber.
#2 Posted : Monday, November 26, 2007 11:31:13 AM(UTC)
The first thing I would check is the pump bearing.
Lift the washer up from the front, remove the belt and check how the pump pulley is moving. If you see any tension or noises, replace the pump.
If this is not the issue, remove the front panel and check for the water leak through the central seal.
- The part number for the pump AP3873289
abbie
#3 Posted : Monday, November 26, 2007 5:16:53 PM(UTC)
abbie
Take the front off the cabinet, look at the bottom at the base. you will see a snubber ring on the base, there will be dust and soap scum under it,try to clean under the ring, then spray some silicone under the ring,and see if that works.
kornkob1
#4 Posted : Friday, September 5, 2008 11:35:13 AM(UTC)
kornkob1
when i push down on the agitater the noise goes away
Admiral washer squeaks during agitation (Washer Repair)
by kukayaker 10/10/2014 10:47:17 AM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Admiral washer drains, but won't spin in wash cycle (Washer Repair)
by WJG 7/19/2014 2:32:36 PM(UTC)
Admiral washer just fills (Washer Repair)
by 73buick225 3/2/2014 3:26:31 PM(UTC)
Admiral washer pls help (Washer Repair)
by nomifish07@aol.com 1/25/2014 12:46:17 PM(UTC)
Admiral washer: Cold water only on warm setting (Washer Repair)
by divemasterjt 11/20/2013 7:18:09 PM(UTC)
Admiral Washer: howling, spinning, smoking... (Washer Repair)
by Noobzilla 7/17/2013 9:03:46 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
admiral washer (Washer Repair)
by jared parsons 9/14/2012 6:33:39 AM(UTC)
by tvanloon43 7/12/2012 7:17:42 AM(UTC)
Admiral washer leak (Washer Repair)
by llimer 3/20/2012 6:10:55 AM(UTC)
Admiral washer agitates during spin cycle (Washer Repair)
by Trenchfoe 3/4/2012 6:55:13 AM(UTC)
Admiral washer agitates but wont drain. (Washer Repair)
by smitty225 2/28/2012 12:04:17 AM(UTC)
Admiral washer wont fill (Washer Repair)
by jay1437 1/15/2012 1:35:43 PM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
