lcramer8
#1 Posted : Wednesday, March 11, 2009 5:53:40 PM(UTC)
lcramer8
My washer fills with water when not on...What do i do?
TechnicianBrian
#2 Posted : Wednesday, March 11, 2009 6:58:52 PM(UTC)
TechnicianBrian
If you have water entering the tub when not in use, then one of the fill valves (AP3128776) is not sealing and is allowing water through the valve. Sometimes the problem will fix itself after a few loads if it is just something like sand in the line causing the problem, but if it keeps doing it, then replace the valve before it gets to bad.
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
Washing machine refills with water after washing cycle finishes (Washer Repair)
by Guest 2/5/2022 9:30:22 AM(UTC)
Washer Fills With Water When Not In Use (Washer Repair)
by shangann 8/4/2016 7:30:14 AM(UTC)
Only fills with water (Washer Repair)
by LauraJones 6/28/2016 2:18:04 PM(UTC)
Roper washer fills with water then nothing else (Washer Repair)
by faunwin12 5/14/2016 6:20:49 AM(UTC)
Washer fills with water after cycle (Washer Repair)
by EdPeters 2/18/2016 8:18:28 PM(UTC)
GE Dishwasher Fills With Water, But No Wash Cycle (Dishwasher Repair)
by wllindsey524 1/27/2016 10:45:34 AM(UTC)
Washer fills with water after Spin Cycle. (Washer Repair)
by Ronin77 2/20/2015 12:01:32 PM(UTC)
Whirlpool Dishwasher Fills with Water then Immediately Drains (Dishwasher Repair)
by jmgcougman 5/3/2014 6:57:05 AM(UTC)
Washer fills with water from tub during spin cycle (Washer Repair)
by LNWilliams 3/5/2014 6:19:11 PM(UTC)
fills with water then drains plz help (Dishwasher Repair)
by cjkinney1981 2/15/2014 12:22:43 PM(UTC)
Washer fills with water after several days while turned off. (Washer Repair)
by jackmharris@hotmail.com 1/30/2014 6:17:27 AM(UTC)
Kenmore washer fills with water and stops (Washer Repair)
by Washer1234 1/25/2014 2:46:25 PM(UTC)
Frigidaire Professional series fills with water and drains, but won't run (Dishwasher Repair)
by Muletown appliance 12/14/2013 11:56:52 AM(UTC)
Front Load Washer Fills With Water When Not In Use (Washer Repair)
by Brewman 9/6/2013 2:15:01 PM(UTC)
