welldave
#1 Posted : Saturday, March 7, 2009 9:29:16 AM(UTC)
welldave
Compressor seems to be in defrost too long. Then the ice will melt and refreeze. Also ice dispenser will not change from crushed to cubed put will pull in with power to it. could I have a problem with a control board?
Drags1998
#2 Posted : Saturday, March 7, 2009 12:09:11 PM(UTC)
Drags1998
YES!!!! It could be the board, Are ALL other motors and lights and temps correct?:)
#3 Posted : Sunday, March 8, 2009 5:28:49 AM(UTC)
Here are our parts
Model Search
Also check the defrost thermostat. Item 240 in Freezer section
Once the ice on the evaporator coil has melted off this should stop the defrost heater.
Drags1998
#4 Posted : Sunday, March 8, 2009 5:44:24 AM(UTC)
Drags1998
True , But He said the compressor was off for to long a time, The Defrost therm. dosent keep the comp. from restarting the Control Board does.:)
#5 Posted : Sunday, March 8, 2009 6:59:26 AM(UTC)
Agree totally
Just something else that he may want to check as "too long" doesn't tell us how long.
welldave
#6 Posted : Wednesday, March 11, 2009 1:24:15 PM(UTC)
welldave
Thanks for the help. Too long is maybe 15 or 20 minutes. and I don't think the evap. has time to freeze. Thank you again. I'll replay again when I get it fixed.
Drags1998
#7 Posted : Wednesday, March 11, 2009 1:33:34 PM(UTC)
Drags1998
20 min is NOT TO LONG!!!!!, Its NORMAL!!!!!!!! Its not a problem if its in defrost for 30 min. Before it goes into "Defrost" It does a 120 min.run time "Pre -defrost "SUPER CHILL" This cools the freezer to -18 so that it dosent warm up during "defrost" Its possible that the ONLY problem that you have is a problem with the Icemaker!!!!!!:)
Freezer Defrost too long (Refrigerator & Freezer Repair)
by kekain 3/31/2009 11:28:44 AM(UTC)
