2 Pages12>
fsw44
#1 Posted : Monday, March 12, 2012 11:01:27 AM(UTC)
fsw44
my dryer is acting up and it does not want to start every once in a while so i took it apart and checked out the start switch and the thermal fuse and the door switch they all check out fine whatelse could be causing this?
JW Webster
#2 Posted : Monday, March 12, 2012 11:17:09 AM(UTC)
JW Webster
Broken belt switch could be going out. It is a micro switch. Might be the motor is going bad.
Simon / APP Team
#3 Posted : Monday, March 12, 2012 11:31:47 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unfortunately it's very hard to proper diagnose the "every once in the while problem". To run the test the dryer has to be "down". The most common problem could be the motor or the timer. Also the door switch may have intermittent problem. Guessing is expensive.
Next time try to push and release the door switch several
times, see if it helps.
The defective belt switch definitely will cause the problem.
Is there anything you do that makes the dryer start?
Please post results.
fsw44
#4 Posted : Monday, March 12, 2012 11:44:48 AM(UTC)
fsw44
i dont think its the motor cause when it runs no smell and it dries everything and runs fine when it starts and there is 3 leads coming to the door switch i have continuity on 2 of them and none on 1 which 1 do i check?
fsw44
#5 Posted : Monday, March 12, 2012 11:52:26 AM(UTC)
fsw44
also wherE will i find the motor switch ?
Simon / APP Team
#6 Posted : Monday, March 12, 2012 1:45:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The belt switch located at the rear motor mounting bracket.
To test the door switch - locate the single wire on one side - common wire (marked C) and with door closed you should have continuity between C and NO. Open the door - continuity between C and NC.
The belt switch Part number: 279782
Part number: 279782
The door switch Part number: AP3132865
Post the results.
JW Webster
#7 Posted : Monday, March 12, 2012 2:26:59 PM(UTC)
JW Webster
Near the motor and idler:
Small white switch with a yellow wire going to it:
http://1.bp.blogspot.com/-va6qJ...tezBHBU1Ts/s1600/030.jpg
JW Webster
#8 Posted : Monday, March 12, 2012 2:28:16 PM(UTC)
JW Webster
Hallerween day I fixed one of these type dryers and made a few photos:
ApplianceJunk.com Blogspot: Kenmore 4-wheel drive dryer de-mystified!:p
fsw44
#9 Posted : Tuesday, March 13, 2012 10:47:40 AM(UTC)
fsw44
ok so i just checked the continuity on the motor switch and it is all 000 so then i checked the door switch and it is all 000's when closed but when open its 001 is the door switch bad then. or is it the motor?
Simon / APP Team
#10 Posted : Tuesday, March 13, 2012 10:56:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Please describe how did you do the tests.
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by 22Hunt 3/18/2013 6:51:01 AM(UTC)
My kenmore dryer wont start (Dryer Repair)
by Mike Swanson 3/11/2010 9:27:48 AM(UTC)
by MOUSENUP 9/5/2009 4:23:59 PM(UTC)
by sargento52 8/30/2009 1:17:44 PM(UTC)
Kenmore Dryer wont start (Dryer Repair)
by rrhoward78 2/1/2009 6:50:52 AM(UTC)
2 Pages12>
