Mike Swanson
#1 Posted : Thursday, March 11, 2010 9:27:48 AM(UTC)
Mike Swanson
I have a kemore ultra fabric care dryer and when i push in the start button the dryer does not start up. Any suggestions
magician59
#2 Posted : Thursday, March 11, 2010 10:25:31 AM(UTC)
magician59
First place to check (and the easiest), is the door switch. Soes the light come on when you open the door? Is there 240VAC at the outlet? If you have power to the dryer, and the door switch is good (you have to test it for continuity), then you should replace these parts. Make sure the vent is clear, form the dryer all the way to the outside. Cycling thermostat Part number: AP3115922
. Thermal cut-off and High limit thermostat Part number: AP3094224
. and Thermal fuse Part number: AP3132867
