I have to keep removing the inlet tube at the top of freezer and let it melt the blockage and then the ice maker will function until the bin is full and it does not run for a day or two and then it freezes up again. Does anyone know if the inlet tube which has wires to it has a "heater" in it or are the wires for a sensor?
Hello. This model has no fill tube heater as you can see on the diagram I'm attaching. The issue is probably the water inlet valve [AP4298444]. Hope this was useful information for you!
Jerry, What are the wires for that connect to teh inlet tube? I have already replaced the valve Thanks Originally Posted by: Jerry / APP Team  Hello. This model has no fill tube heater as you can see on the diagram I'm attaching. The issue is probably the water inlet valve [AP4298444]. Hope this was useful information for you!
If your talking about the four wire harness,(white, red, tan, and green) it powers the icemaker and water valve. If you could send a picture as an attachment I could better help you.
No I am talking about the white and black wires that are connected to the inlet tube. I acess the inlet tube from the top of the ref. Originally Posted by: Spb4444  Jerry, What are the wires for that connect to teh inlet tube? I have already replaced the valve Thanks
I must apologize. I've been looking up a generic model number since you model listed wasn't complete. There are about 25 or 30 model numbers that start as your listed number starts. I did find a model with a fill tube heater [AP3040826]. I'm not sure this is exact for your model. If I had your complete number I could get the exact part number. I'm sorry if this an inconvenience.
I think the part number is AP5330657 But the model number is KSSC42QTSOO Originally Posted by: Jerry / APP Team  I must apologize. I've been looking up a generic model number since you model listed wasn't complete. There are about 25 or 30 model numbers that start as your listed number starts. I did find a model with a fill tube heater [AP3040826]. I'm not sure this is exact for your model. If I had your complete number I could get the exact part number. I'm sorry if this an inconvenience.
Hello. I found the part number for the ice maker fill tube heater [AP5330657]. The original number was [AP3180767] but I'm not sure it is still available. You had come up with the correct part number. I apologize for the inconvenience. Feel free to contact us if we can assist further.
I just want to know if the tube has a heater in it or if the wires are for a sensor of some type before I order it thanks
The wires are for a fill tube heater. The heater was an add on after manufacture by the manufacturer. Have a great day!
