DHD57
#1 Posted : Friday, January 20, 2012 5:37:18 AM(UTC)
DHD57
Had a tech diagnose the problem, a bad control board. Ordered it and replaced it myself. Now clean light blinks constently.
Jerry / APP Team
#2 Posted : Tuesday, March 6, 2012 6:28:32 AM(UTC)
mattt
The clean light blinking 7 times is a fault code for the water heating circuit on board the unit. If the control doesn't see a predetermined increase of temperature in a set amount of time, the code will flash. First off, be sure you always run the hot water at the sink before starting a cycle to shorten the wash cycle. The most probable cause of this fault code is the heating element going open. Other possible causes are the door switch [AP3039128], the control board [AP3775506], the Hi-limit thermostat [AP3010530], and the wiring harness. Of course the first thing I would recommend is to visually inspect the heating element Heating element kit- This dishwasher heating element is for stainless steel tubs only. Includes a new computer board that needs to be replaced along with the element. For plastic tubs use [AP4325066]. Part Number: [AP3841139] . If it has burned in to of course it will need replacement. If there is a white place, or much lighter place present it will need to be tested to ensure your not replacing a good part. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html . The wiring diagram should be found behind the kick panel and will guide you to the fore-mentioned components which you may need to test. After repair you will also have to place the unit into the diagnostic mode to reset the control so it can run through cycles again. This procedure is as follows: On the control panel....heated dry,normal,heated dry,normal - OR - High temp,air dry,high temp,air dry. These keys must be pressed within 10 seconds to set the control into diagnostics. At this point you can allow it to go all the way through the self-diagnostic cycle or you can press cancel. Sure hope this helps you solve your problem!
Viking dishwasher repair (Dishwasher Repair)
by AngelaH 8/29/2023 8:48:21 AM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
Appliances Repair North York || Dishwasher Repair (Refrigerator & Freezer Repair)
by digitallab 7/8/2021 8:45:33 AM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Samsung dishwasher repair (Dishwasher Repair)
by Cougar6069 5/5/2020 6:01:38 PM(UTC)
Dishwasher repair - kitchenaid briva KIDS36EPSS0 (Dishwasher Repair)
by magicmarc 1/8/2020 5:56:50 AM(UTC)
Bosch SHU9915UC/U11 Dishwasher repair (Dishwasher Repair)
by Yariet 11/4/2019 6:35:40 AM(UTC)
Bosch dishwasher repair (Dishwasher Repair)
by 66FSTbck 10/13/2018 7:34:04 AM(UTC)
Portable Dishwasher Repair (Dishwasher Repair)
by cliff10 1/7/2018 8:53:54 AM(UTC)
by maytagman17 9/26/2015 11:33:06 AM(UTC)
Dishwasher Repair - No water (Dishwasher Repair)
by maytagman17 9/26/2015 11:25:01 AM(UTC)
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
by sun47me 11/27/2013 4:46:52 PM(UTC)
Dishwasher repair.. (Dishwasher Repair)
by mssorcha51 9/11/2013 1:30:07 PM(UTC)
Bosch dishwasher repair help (Dishwasher Repair)
by jeanettekoster 10/30/2012 1:58:10 PM(UTC)
