shrtcircut
#1 Posted : Thursday, March 5, 2009 7:47:49 PM(UTC)
shrtcircut
Dryer tumbles fine, but not a hint of heat
#2 Posted : Friday, March 6, 2009 7:08:09 PM(UTC)
There are five major electrical parts involved in the heating process:
1. Cycling thermostat
2. High limit thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 ± 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
How to locate these parts in your dryer?
Type the model number (the name plate is on the door frame) in the search box, click the “search” button and you will be directed to the break down diagrams.
Using the break down diagrams, locate the part you’re looking for.
- The part number for the cycling thermostat is AP4037199
- The part number for the high limit thermostat is AP4036956
- The part number for the igniter is AP4037378
- The part number for the flame sensor is AP2910747
- The part number for the gas valve coils kit is AP3094251
Good luck.
shrtcircut
#3 Posted : Friday, March 6, 2009 7:40:29 PM(UTC)
shrtcircut
Thanks Gene,
I found out after taking the front panel off, that the igniter was cracked. There was no continuety between the leads. I installed a new one aand the dryer works fine . Thankyou
#4 Posted : Friday, March 6, 2009 7:43:29 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
