GHT
#1 Posted : Monday, February 27, 2012 12:12:56 PM(UTC)
GHT
Door latch would not work, thus, could not use the oven. To see if door latch worked, I initiated self cleaning and 30 seconds later, cancelled the cleaning...the door latch worked when cleaning cycle started, but now the door will not unlock..any suggestions? I already unplugged it for a half hour and plugged it back in, no change...
#2 Posted : Monday, February 27, 2012 4:24:29 PM(UTC)
Use a metal coat hanger with a loop in the end, try to hook the latch to open the door.
Here are the breakdown diagrams and Replacement parts for Whirlpool GMC305PDS2 ELECTRIC OVEN/MW COMBO | AppliancePartsPros.com
door will not unlock (Washer Repair)
by Mike Hall 10/27/2011 4:13:33 PM(UTC)
Washer door will not unlock (Washer Repair)
by Linda Hopkins 1/22/2010 9:44:25 AM(UTC)
Thermador oven door will not unlock (Oven Repair (including Ranges and Cooktops))
by nat1rlw 7/22/2009 10:31:03 AM(UTC)
by telleria 8/22/2008 12:15:24 PM(UTC)
Oven Door will not unlock (Oven Repair (including Ranges and Cooktops))
by dshefley 6/27/2008 10:57:52 AM(UTC)
help my oven door will not unlock!! (Oven Repair (including Ranges and Cooktops))
by mmtucker 1/3/2008 7:43:21 AM(UTC)
