tmagolas@rogers.com
#1 Posted : Monday, February 20, 2012 11:16:12 AM(UTC)
tmagolas@rogers.com
I HAVE A kITCHENAID SIDE BY SIDE FRIDGE W/ WATER DISPENSER & ICE MAKER MODLE# KSRS25ILSS03.
THE ICE MAKER STOPPED WORKING AFTER I SHUT OF THE ICE MACHINE FOR 3 WKS. NO WATER GETTING INTO THE ICE MAKER TRAY. THE RED LITE BLINKS 2X THEN PUSES FOR2 SECONDS WHEN DOOR IS OPEN. WHEN I PUSH THE FLAP SHUT, THE RED LITE STAYS ON WITHOUT ANT BLINKS. i TRIED THE BLOWDRYER TO THE WATER SUPPLY TIP BUT NOTHING. AFTER 7 HRS. READING FORUMS NOT SURE IF I NEED TO REPLACE THE ICEMAKER, FILL VALVE, OR THE SENSORS ON BOTH SIDES OF THE WALL PANELS.
TOM
ApplianceJunk
#2 Posted : Monday, February 20, 2012 12:16:58 PM(UTC)
ApplianceJunk
I would make sure the water line that goes to the ice maker is not frozen shut before I decided to replace any parts.
Here is the service manual for your ice maker. Maybe you will find it helpful.
http://appliancejunk.com...ownloads;sa=view;down=43
tmagolas@rogers.com
#3 Posted : Tuesday, February 21, 2012 12:53:34 PM(UTC)
tmagolas@rogers.com
Thx For The Qick Reply Aj. I'll Take The Ice Machine Out Completly And Fish A Coat Hanger In The Hose And See How Far In It Goes. If The Hose Is Frozendeeper Inside Around The Insulated Part, What Method Do You Suggest To Unglog The Ics? Replace The Hose?
tmagolas@rogers.com
#4 Posted : Sunday, March 4, 2012 7:23:23 AM(UTC)
tmagolas@rogers.com
I replaced the water vale and still no change from before. I did notice the teeth that pops the ice out into the bucket are notsticking out, they are inside the ice machine, A repair person told me that that is a good sign to replace the ice machine. I don't have a problem replaceing it aslong as I know that is the problem. I was also told using a electrical wire, I could jump something on the mortor and that will open the vale and allow water into the ice machine. This is only a trouble shooting test. But I did not quite understand where to look for the "N-L" & "T-H"
no water in icetray (Refrigerator & Freezer Repair)
by jam 1/7/2008 9:47:07 AM(UTC)
