swallman
#1 Posted : Saturday, February 18, 2012 5:29:58 AM(UTC)
swallman
Freezer isn't defrosting, causing fridge to be warm. Can't determine if our fridge has a defrost timer or if it is controlled by the electronic module. If someone can just post the correct part numbers to check, I think I can take it from there.
Thanks!
swallman
#2 Posted : Saturday, February 18, 2012 2:49:49 PM(UTC)
swallman
OK...got everything emptied out and defrosted the freezer manually. Checked the defrost heater and it appears ok. Checked the fridge thermistor (warm) and it is showing around 14,000 ohms. Freezer thermister I'm not sure about since I'm not completely sure what specific jumpers it connects to on the board to check it ?
I'm a bit concerned about replacing the freezer thermistor since the wiring appears to go somewhere in the cabinet that looks like it would be a PITA to replace.
Simon / APP Team
#3 Posted : Saturday, February 18, 2012 3:50:52 PM(UTC)
Simon / APP Team
Groups: APP Team
Locate the defrost thermostat (shown on the following picture).
UserPostedImage
Check the defrost thermostat for continuity. It must be ice-cold at the time of the test.Post the results and the serial number of the refrigerator.
swallman
#4 Posted : Sunday, February 19, 2012 4:56:22 PM(UTC)
swallman
UserPostedImage
I'll check that tomorrow evening and post back. I was able to do all the "tests" from the circuit board (fridge, freezer thermistor tests, etc.) and everything passed (at least from what I understand reading the results).
Thanks.
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 9/13/2017 12:37:45 PM(UTC)
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 2/3/2017 10:58:43 AM(UTC)
by smokyjoeko 4/7/2015 7:44:59 AM(UTC)
defrost not working (Refrigerator & Freezer Repair)
by carlosl. 5/15/2013 8:35:28 PM(UTC)
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 4/30/2012 2:50:08 PM(UTC)
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 9/21/2011 3:22:27 PM(UTC)
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 10/13/2010 4:33:52 PM(UTC)
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 7/21/2010 2:43:00 PM(UTC)
by smodellb 3/28/2010 5:02:17 PM(UTC)
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 2/6/2010 6:19:27 AM(UTC)
by red arrow 57 10/18/2009 7:35:40 AM(UTC)
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 9/19/2009 8:19:56 AM(UTC)
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 8/31/2009 5:03:59 PM(UTC)
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 6/30/2009 6:05:59 AM(UTC)
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 3/27/2009 6:28:53 AM(UTC)
