psa
#1 Posted : Sunday, February 22, 2009 5:56:19 AM(UTC)
psa
I have Kitchenaid Model KUIS185JWHO ice maker and it will make ice for sometimes as long as 3 or 4 days and then it will not release the slab and build up until it runs out of water. If I turn it off and let the slab melt it will run for awhile and do it again. I have descaled the evaporator and it looks perfect. The machine is 9 years old. I have checked the voltage at the hot gas solenoid it is 122 volts ac. The cycle time for making a slab of ice is about 25 minutes hot gas time is about 2 minutes. Also what dose the thermister under the evaporator do? I have no way to check to see if it needs Freon other than the time it takes to make ice.
Any help would be appreciated.
Wayne
psa
#2 Posted : Monday, March 2, 2009 2:53:00 PM(UTC)
psa
The problem was a cracked evaporator thermistor. It would check good and then every now and then it would open.
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Frigidaire FGHS2631PF4A Ice Buildup in Freezer (Refrigerator & Freezer Repair)
by Visualist 12/28/2021 9:16:05 AM(UTC)
GE MONOGRAM ZIC360NMRH Ice Buildup (Refrigerator & Freezer Repair)
by Dawnv 10/11/2021 7:01:04 AM(UTC)
Samsung RS261MDRS ice buildup (Refrigerator & Freezer Repair)
by AndyPanda 2/23/2020 6:24:11 PM(UTC)
Whirlpool WRT311FZDW00: Ice buildup in freezer, warm fridge (Refrigerator & Freezer Repair)
by bkbk 9/16/2019 3:42:31 PM(UTC)
KitchenAid Side-by-Side Freezer Ice buildup and cold Fridge (Refrigerator & Freezer Repair)
by Kinny82 10/15/2017 9:36:39 PM(UTC)
Old Amana Bottom Freezer with Ice Buildup (Refrigerator & Freezer Repair)
by egizzi 2/17/2017 6:39:34 AM(UTC)
Ice buildup behind fridge. (Refrigerator & Freezer Repair)
by Chadmc23 11/29/2016 3:44:06 PM(UTC)
GE Frost/Ice Buildup on Ice Chute (Refrigerator & Freezer Repair)
by timabe 4/16/2016 5:47:26 AM(UTC)
Amana Side by Side Ice Buildup and Leaking (Refrigerator & Freezer Repair)
by LavaPit 8/25/2014 10:13:44 AM(UTC)
ice buildup on the pack panel inside fridge (Refrigerator & Freezer Repair)
by bluefitness 8/3/2014 6:21:29 PM(UTC)
Ice buildup on one side of evaporator coils (Refrigerator & Freezer Repair)
by Lott 6/18/2014 6:39:59 PM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
Ice buildup (Refrigerator & Freezer Repair)
by DonQuixote 11/12/2012 9:45:19 PM(UTC)
freezer ice buildup on bottom of floor (Refrigerator & Freezer Repair)
by donzell 7/26/2012 1:45:47 PM(UTC)
