jonvinette
#1 Posted : Monday, February 13, 2012 7:57:20 AM(UTC)
jonvinette
ran a load through it one day and came back to find the water drained but it did not spin checked it out a lil to find that the belt had been burned out so i replaced it only to have the same thing happen again this time i checked the pump to make sure it was not plugged up it was not pulled it apart and find that the tub is binding up for some reason and cant figure this out going crazy please help.
sidfink43
#2 Posted : Tuesday, February 14, 2012 5:12:56 PM(UTC)
sidfink43
Usually the Kenmore 70 Series are Whirlpool made machines without a belt, so I am not sure what you have. Please post the model number with the three digit prefix so we can see exactly what machine you have.
jonvinette
#3 Posted : Wednesday, February 15, 2012 5:16:09 AM(UTC)
jonvinette
its an old machine from sears roebuck and co. i cant really make out the first digit but it looks like 110 and it is a 70 series heavy duty plus if that helps any.
sidfink43
#4 Posted : Wednesday, February 15, 2012 5:35:47 AM(UTC)
sidfink43
Ok, if this is really the older model belt driven Whirlpool made machine than it is much older than the 5-10 years you posted and I think you should consider a replacement. You have more, much more than gotten your money's worth here.
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Kenmore 70 series washer doesn't work (Washer Repair)
by kman6206 1/17/2015 3:38:49 AM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
Kenmore 70 Series Washer wont drain (Washer Repair)
by English638 8/8/2012 8:20:21 PM(UTC)
Kenmore 70 series washer will not spin or agitate (Washer Repair)
by boseman75 8/5/2012 2:45:56 PM(UTC)
Kenmore 70 series washer was rattling, now buzzes and won't go (Washer Repair)
by dapaulson 1/12/2012 11:06:24 AM(UTC)
kenmore 70 series washer won't agitate or spin (Washer Repair)
by jjd2009 7/4/2011 8:42:09 AM(UTC)
Kenmore 70 series washer wont agitate, spin, or drain (Washer Repair)
by xiuzhiwu 7/18/2010 9:10:46 AM(UTC)
Kenmore 70 Series Washer - no cold water, weak spin cycle? (Washer Repair)
by PHRoberts 1/14/2010 1:46:45 PM(UTC)
How to remove the casing for Kenmore 70 series Washer (Washer Repair)
by clair 9/21/2009 3:13:41 PM(UTC)
kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump (Washer Repair)
by pkme 1/26/2009 9:54:13 PM(UTC)
Kenmore 70 series washer (Washer Repair)
by Jody G 1/4/2009 8:35:48 PM(UTC)
kenmore 70 series washer (Washer Repair)
by lafamiliallanes 5/17/2008 4:27:09 PM(UTC)
