The washer will not power up when start button is pushed. where do i start? We checked the electrical outlet and there is power coming to the washer. The switch appears to be part of a circuit board (makes a click sound when pushed) thanks for your help
try checking the id switch that may be the problem sure sounds like it
Did you mean lid switch? I'm having a similar problem with my Kenmore 2120.
