My daughter's oven had the top oven element burn up and melt in two on Thanksgiving day. The element was ordered and replaced but the oven will not heat. All lights and indicators work. The breaker is good. Could some controller circuit board or internal fuse be bad. The oven is approximately 18 months old. the model # is 790-46613502
How do I verify this? Thanks.
Do both Broil and Bake not working or just the Broil?
Both the broiler and the oven will not work. I am going to my daugher's house tomorrow with an ohmmeter
Both the oven and the broil don't work.
Pull the range out of the wall, remove the rear panel and check the thermal cutout for continuity. If there is nothing wrong then you have to find the wiring diagram and perform the troubleshooting according to the diagram. If you are not sure how to do it then post the wiring diagram and we'll help you. - The part number for the thermal cutout is AP3874781Gene.
