Glenn927013
#1 Posted : Friday, February 6, 2009 6:52:15 AM(UTC)
Glenn927013
My daughter's oven had the top oven element burn up and melt in two on Thanksgiving day. The element was ordered and replaced but the oven will not heat. All lights and indicators work. The breaker is good. Could some controller circuit board or internal fuse be bad. The oven is approximately 18 months old. the model # is
790-46613502
How do I verify this? Thanks.
#2 Posted : Friday, February 6, 2009 7:48:32 PM(UTC)
Do both Broil and Bake not working or just the Broil?
Glenn927013
#3 Posted : Monday, February 23, 2009 3:03:51 AM(UTC)
Glenn927013
Both the broiler and the oven will not work. I am going to my daugher's house tomorrow with an ohmmeter
Glenn927013
#4 Posted : Monday, February 23, 2009 3:06:43 AM(UTC)
Glenn927013
Both the oven and the broil don't work.
#5 Posted : Monday, February 23, 2009 10:38:29 AM(UTC)
Pull the range out of the wall, remove the rear panel and check the thermal cutout for continuity. If there is nothing wrong then you have to find the wiring diagram and perform the troubleshooting according to the diagram. If you are not sure how to do it then post the wiring diagram and we'll help you.
- The part number for the thermal cutout is AP3874781
Guest (4)
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
by davidwhop 8/31/2014 7:17:47 AM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 9/27/2013 5:08:44 PM(UTC)
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 6/9/2013 9:01:10 PM(UTC)
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 4/22/2013 5:43:12 AM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 3/19/2013 8:47:44 AM(UTC)
by Pjcibulski 1/29/2013 2:00:44 PM(UTC)
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 1/18/2013 12:14:24 PM(UTC)
