dbeharry
#1 Posted : Monday, February 23, 2009 5:21:26 AM(UTC)
dbeharry
Ice maker stopped making ice. Replaced the solenoid, which didn't work, but in the process remedied a low water flow problem by replacing the saddle-type supply valve. Still no ice.
This has the "optical" sensor, and when the door is open, the status LED gives two flashes, a longer pause, two flashes, etc. When I press in the paddle switch on the left side, the LED is on steadily.
The fill tube at the top is not itself frozen, but I can't tell if there is freezing above it.
Any thoughts?
ApplianceJunk
#2 Posted : Monday, February 23, 2009 6:21:43 AM(UTC)
ApplianceJunk
Can you disconnect the water line the goes to the ice maker from the water valve in back of the refrigerator and blow air through it?
dbeharry
#3 Posted : Monday, February 23, 2009 6:29:22 AM(UTC)
dbeharry
I will have to pull the refrigerator out to get access to it, but I can do that. Do I assume that is the test to see if there is freezing somewhere in the line?
ApplianceJunk
#4 Posted : Monday, February 23, 2009 7:10:26 AM(UTC)
ApplianceJunk
Yes, that is the test to see if the line is frozen.
If you can not blow air through it then that is the problem.
dbeharry
#5 Posted : Monday, February 23, 2009 7:13:25 AM(UTC)
dbeharry
Thanks, very much. I won't be able to try that for a couple of hours, but I will give it a shot and let you know what the result is.
ApplianceJunk
#6 Posted : Monday, February 23, 2009 7:17:35 AM(UTC)
ApplianceJunk
Sounds good, let us know. :)
dbeharry
#7 Posted : Monday, February 23, 2009 8:55:51 AM(UTC)
dbeharry
I did what you suggested, and it seemed that, although it was difficult, some air did move through the tube. (I tried the other line first, which is slightly larger diameter, and no air moved through it, so I assume that was the line for the water dispenser.
Any further thoughts?
#8 Posted : Tuesday, February 24, 2009 2:12:08 PM(UTC)
Perform the ice maker troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...-maker-quit-working.html and post the results.
Guest (4)
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
