25 Pages«<89101112>»
Eds 3rd
#91 Posted : Tuesday, January 10, 2012 3:54:35 AM(UTC)
Eds 3rd
Gene,
The water tray DID NOT fill when I jumpered the "T" and "H" Test Points.
MORE INFORMATION SINCE I LAST POSTED: After work yesterday, I decided to proceed with additional troubleshooting of the water valve. To double check there was no ice in the fill line, I disconnected the ice maker water line from the water valve and used my air compressor to blow through the line (with assistance from spouse) and checked for air flow at the fill tube inside the freezer (no clogging at all). Since I was confident that wasn't the problem, I reconnected the water line and removed both electrical connectors to the water valve. I then attempted to connect the purple connector for the in-door water dispenser to the water valve for the ice maker but quickly determined that it would not connect (different size connectors). To get around this I decided to install two jumper wires from the purple (in-door water) connector to the valve for the ice maker. I taped the emitter door closed to ensure the light beam was not blocked, taped down the freezer door button to simulate the door being closed, taped the ice maker door in the open position to see the water fill tube, reconnected power and when I depressed the in-door water dispenser lever, "presto" -- water began filling the ice maker. Correct me if I'm wrong, but doing this verified that the water valve is GOOD and that my problem now is related to some other part not sending 120 VAC to the ice maker valve (result = no water due to the valve remaining in the closed position)?
I must admit that I was hoping water would NOT dispense when the in-door water lever was depressed during the "jumpered" test which would in-turn indicate a defective water valve (much cheaper to replace than the cost of an entire ice maker)?
Oh well, I'm hoping AppliancePartsPros will take back the kit for the emitter/transmitter if I have to purchase a IM.
Before I order anything else, I would greatly appreciate your opinion on what part needs to be replaced to fix my problem. Do I have to purchase an entire IM or can I simply replace another (less expensive) component (i.e., thermostat)?
#92 Posted : Tuesday, January 10, 2012 4:45:34 PM(UTC)
Very likely the problem is a bad ice maker. I do not recommend to fix the existing ice maker because we don't know exactly which parts to replace and very low rate on successful ice maker repairs.
AppliancePartsPros will definitely take back any parts you purchased from the company, but I would recommend to replace the ice maker first. Then check it with the new optics and, then with the old kit. Only when you'll be sure it does work with the old kit, return the new one. You have 365 days for returns.
- The ice maker Part number: AP3182733
webhale
#93 Posted : Wednesday, January 11, 2012 6:04:15 PM(UTC)
webhale
Gene,
I assume that I need to replace the ice maker unit on a KSBS25INBL00 Kitchenaid base on the conclusions above. I have 120V power through points L & N, but the jumper in T & H did not produce any movement. Do you agree, or is there some other possible solution?
#94 Posted : Thursday, January 12, 2012 1:48:50 PM(UTC)
Hi John,
You may want to run the test described in the attached file. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSBS25INBL00 REFRIGERATOR | AppliancePartsPros.com
File Attachment(s):
MANUALLY STARTING AN IDI ICE MAKER.doc (20kb) downloaded 119 time(s).
webhale
#95 Posted : Thursday, January 12, 2012 5:27:50 PM(UTC)
webhale
Gene,
I did the manual start procedure, but the Ice maker did not run.
#96 Posted : Sunday, January 15, 2012 3:46:04 PM(UTC)
John,
Looks like the ice maker has gone bad. You can use the same ice maker as listed above.
Eds 3rd
#97 Posted : Wednesday, January 18, 2012 11:36:23 AM(UTC)
Eds 3rd
Greetings Gene,
I'm the guy (Eds 3rd) that had the inoperative ice maker on the KitchenAid Refrigerator (Model # KSRP25FNSS00). Anyway, I followed your advice and ordered the entire IM assembly and "presto", everything worked as advertised. Once I knew everything was working as advertised, I unplugged the fridge and swaped the optics P.C. kit (emitter & transmitter boards) and plugged it back in.
Again, "presto", everything worked good. I must admit that I was a bit skeptical that AppliancePartsPros would take back this part (especially since it is an electrical item and most appliance parts stores will not accept a return), but was glad to hear that I will get a "Full Refund"!!
I am completely overwhelmed with this company and sent them an e-mail expressing my appreciation (especially the exceptional troubleshooting assistance I received from you -- Thanks again for everything)!!
Rest assured that I will use you exclusively for all future appliance parts purchases and will recommend you to all of my friends. GOD BLESS!!:) :) :)
#98 Posted : Wednesday, January 18, 2012 1:18:55 PM(UTC)
You are welcome. Thank you for your good words!
Adam / APP Team
#99 Posted : Wednesday, January 18, 2012 1:50:51 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Originally Posted by: Eds 3rd Go to Quoted Post
Greetings Gene,
Thank You Eds 3rd,
Glad to hear you are satisfied with our service.
Also know that any part purchased from us within a year has a replacement warranty. Which means you dont need to return the defective part purchased from us. We just send you out a replacement and you hold the defective part for 30 days before discarding.
Please call our toll free number 1-877-477-7278 if you have any questions.
Ppaolillo
#100 Posted : Wednesday, March 14, 2012 12:04:54 PM(UTC)
Ppaolillo
Ksrp25fnss00
The side by side frig is having an issue. The ice maker is not working. The status lights when having the freezer door open. And holding the left most white flapper held down. The status led on the right flashes twice and then one second off. And then repeats two flashes also having a second spacing. Blinking.
I have checked the valve seloniod the one to the water works when one pushes the water handle down it puts 5vdc across the seloniod and it makes the water flow.
On the same valve there is another seloniod for the ice maker. It seems that one is not getting a voltage applied.
As a check. I swapped the water glass seloniod connector with the ice maker seloniod input. They were not interchangeable due to the connector types so I simply held it implace to the ice maker seloniod and had someone type to fill a glass of water. As soon as I did that the seloniod activated the pump and water was successfully flowing out of the ice maker feed line.
I then buzzed out the original ice maker seloniod wiring successfully back to the top of the ice maker.
That tell me the wiring is good to that point. If I disconnect the inline connector that will disconnect the ice tray itself.
It is clear to me that the ice maker tray is not turning on the water valve to the ice maker. It is either in the tray itself or the control led beam. I tried to use a camera to see the flashes of the infrared transmitter In doing that I did not see a beam which would suggest te transmitter may be bad. The control board on the right side was removed. No visable scoring was detected on the board. Can someone help.
Paul
Guest (13)
