smartin349
#1 Posted : 13 years ago
smartin349
My dryer will not automatically shut off when in the sensor mode. What do you think the problem is?
#2 Posted : 13 years ago
Replacement parts for MAYTAG MDET446AYW DRYER- ELE | AppliancePartsPros.com
Check/clean your moisture sensor.
The machine may think that the clothes are still wet.
The way it works is that a voltage is applied to the 2 metal strips.
When moisture or dirt/residue is between the strips a current flows and the board senses this and continues to run.
Clean between the strips with a damp cloth and dry.
If this does not work try isopropyl alcohol, just be sure to let the vapors dissipate before trying it.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
by Mickey_951 14 years ago
Dryer Problems (Dryer Repair)
by Tsailor 14 years ago
Dryer problems (Dryer Repair)
by Shoopes 15 years ago
by talbot 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 15 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
by berniefl 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by mbgrdido 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
by Myles.Smith 17 years ago
