esquino
#1 Posted : Saturday, November 17, 2007 8:25:57 AM(UTC)
esquino
I turned the power off to the unit after not getting heat. The furnace cycles fine the first time but will not recycle. If I turn the power on and off again the unit again cyles fine the first time but goes no further.
On cycles after the first, the plug glows, the burner fires but after a few seconds the burner cuts off. Again, it only does this after the first cycle sucessfully completes.
Basically, if I continue to reset the furnace after each cycle it works great. If I leave it alone it only cycles once then continue to try to fire without sucess.
kooler
#2 Posted : Sunday, November 18, 2007 9:04:31 PM(UTC)
kooler
There's a safety device shutting this unit off and there's a lockout relay purposely leaving the unit off... You'll need a pro to troubleshoot this one... Turning the power off and back on resets the relay... Could be one of a number of problems or a combination... Search out all the safety devices in the wiring diagram and investigate each one is all I can recommend... good luck...
Guest (4)
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
oven cycle light comes on and goes off when oven is not on (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2024 7:45:28 AM(UTC)
Opened lid to add something to washer after it started and now the cycle won’t start again (Washer Repair)
by Guest 2/25/2024 6:18:56 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag MVW7232HW0 Will Not Complete a Cycle (Washer Repair)
by JNN1988 2/7/2024 8:29:57 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Kitchenaid quits mid cycle, goes to cancel/drain (Dishwasher Repair)
by T_mich 2/4/2024 11:11:49 AM(UTC)
GE GTW465ASN1WW cycles fill-drain, repeat (Washer Repair)
by DoodahDenn 1/31/2024 12:19:12 PM(UTC)
Maytag MDB4949SHZ1 will not complete cycle (Dishwasher Repair)
by Bojacked 1/3/2024 2:12:38 PM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
LG front load knocking during cycle (Washer Repair)
by Guest 11/23/2023 1:51:40 PM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Whirlpool WTW5700SW0 Washer -- Clothes Wet After Cycle Completes (Washer Repair)
by npolite 11/9/2023 1:24:23 PM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
