AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool WTW5700SW0 Washer -- Clothes Wet After Cycle Completes
Hi All,
Our Whirlpool washer is having issues at times spinning the drum when either on the first drain or second. This doesn't happen all of the time but I do notice after a cycle is complete that the clothes are soaked with water. If I move the drum a little and try to spin them it will work. Is this a transmission issue or something else?
I also have an issue with pooling water on the right side. It seems to only happen when I am using the large or extra large load. I tried looking for leaks but haven't been able to find anything.
I am able to troubleshoot if needed.
Thanks,
Nick
Washer Repair
