9 Pages«<23456>»
#31 Posted : Friday, December 30, 2011 12:37:14 PM(UTC)
OK. But this is very strange:
Quote:
...cant seem to get a reading from the overtemperature thermostat ?...
It has nothing to do with the board.
ws6s
#32 Posted : Saturday, December 31, 2011 7:53:10 AM(UTC)
ws6s
gene just to make sure of myself.would i remove the overtemp thermostat from the unit to test it while still cold ?
ws6s
#33 Posted : Sunday, January 1, 2012 1:53:07 PM(UTC)
ws6s
OK. But this is very strange: It has nothing to do with the board.
ok gene i put the new new main board on around 6 hours ago and it is running great and cooling as it should.hopefully it ill stay this way.
#34 Posted : Monday, January 2, 2012 1:53:42 PM(UTC)
I hope so. Good luck!
ws6s
#35 Posted : Wednesday, January 4, 2012 7:59:40 AM(UTC)
ws6s
she is working fine and holding steady at 0 and 37.
thanks for your help.
todd :)
#36 Posted : Wednesday, January 4, 2012 12:30:52 PM(UTC)
You are welcome Todd. I'm glad you were able to fix it after all. The bad thing is that you can not rely even on brand new parts any more.
ws6s
#37 Posted : Sunday, January 29, 2012 3:38:44 PM(UTC)
ws6s
ok gene guess what ,
thats right its messin up again !
fridge seems to be holding 36 / 37 degrees but the freezer is around 15 / 16 and the fan constantly runs in the freezer i guess to keep tryin to cool it down.
should i get another main board ordered ?
Thanks Todd
#38 Posted : Thursday, February 2, 2012 2:53:20 PM(UTC)
Hi Todd,
Sorry for the delay.
Can you post detailed (part by part, what is does and what it does not) description on the problem please?
ws6s
#39 Posted : Friday, February 3, 2012 4:38:16 AM(UTC)
ws6s
freezer fan constantly runs freezer will not get below 22 degrees,once i put a new main board it will work for a few weeks and then repeat the same cycle.they are sending me a 3rd main board that should be here today,i wonder if something else is frying the main boards and causing the issue ?
thanks todd...
ws6s
#40 Posted : Friday, February 3, 2012 1:09:51 PM(UTC)
ws6s
thanks todd...
or could it be 3 bad main boards ?
Guest (14)
9 Pages«<23456>»
