4 Pages<1234>
wavesys
#11 Posted : Thursday, February 19, 2009 12:03:02 AM(UTC)
wavesys
The voltage at the outlet is OK. The motor runs for a short time and then is shut off. I would like to wire the motor directly to a power cord to make sure it is not being shut off by the timer. Do you have a wiring schematic?
#12 Posted : Thursday, February 19, 2009 11:29:08 AM(UTC)
Originally Posted by: wavesys Go to Quoted Post
...The motor was full of lint and I have blown it out with an air compressor...
This is the most common cause for a motor to get bad due to overheating. In addition if you are not able to restart the dryer right after it stopped and/or it makes an unusual (humming) noise at time of start up then it proves that the motor has gone bad.
Unfortunately, I do not have the wiring diagram, but you probably can find it inside the control panel.
floodbc12
#13 Posted : Monday, February 23, 2009 7:56:07 AM(UTC)
floodbc12
i have a whirlpool model tedx640pq0 electric dryer and it will only heat for about 2 min and then the heating element turns off. if i let the dryer sit for about an hour to completely cool down and turn it back on the process repeats. i think its one of the thermostats but i have no way to test them. is there a certain one that would cause this to happen? there is a cycling, high limit, and a thermal cut off shown on the diagram of my dryer
#14 Posted : Monday, February 23, 2009 10:52:23 AM(UTC)
floodbc12,
The first thing I would do is clean the vent line all the way to the outlet and all air ducts and the blower inside the dryer.
What did you mean saying: "I have no way to test them"?
Here are the break down diagrams and the parts list for the Roper dryer Model TEDX640PQ0
floodbc12
#15 Posted : Tuesday, February 24, 2009 6:49:57 AM(UTC)
floodbc12
i've cleaned the whole dryer as you have described and it still is doing the same thing. i ment that i do not have any sort of tester to see if the thermostats are working properly. just dont know which of the thermostats would cause the problem im having
#16 Posted : Tuesday, February 24, 2009 1:27:18 PM(UTC)
You have to have a simple multimeter to perform the troubleshooting. Replacing parts by guessing can be very costly.
vgstein
#17 Posted : Friday, February 27, 2009 11:38:27 AM(UTC)
vgstein
Unrelated note: I'm testing an igniter for Kenmore gas dryer (model 110.73932101) with digital multimeter and it reads 00.0 after going through a few other numbers (set at 20K ohms). Does that mean the ignite is good/bad or sth else? thanks.
#18 Posted : Friday, February 27, 2009 12:14:35 PM(UTC)
You set the meter on very high range.
vgstein
#19 Posted : Friday, February 27, 2009 12:30:56 PM(UTC)
vgstein
Okay, so at 200 it reads 64-65 and at 2K it reads .59
Is this good?
#20 Posted : Friday, February 27, 2009 2:17:22 PM(UTC)
The igniter is good. Check the thermal fuse for continuity.
Guest (4)
4 Pages<1234>
