Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: dragonboy  ...the dryer continues to tumble, but does not stop and there's no heat... Does it do it on all cycles? Try the dryer on "no heat" cycle. Gene.
Thanks for responding Gene.
No heat on any cycle, but I'll check the timer to see if it works on "no heat" cycle. Also, do you know how to check the heat coil and where it's located?
