TOPPSAUTO
#1 Posted : Monday, February 9, 2009 4:25:17 PM(UTC)
TOPPSAUTO
my microwave has no heat. everything else seems to work normally.
the capacitor is not charging so I replaced it along with the diode, the diode reads different #s than the original but it was matched to the capacitor which matches #s on my original capacitor. There is 120 volts going into the transformer when running but the capacitor still has no charge.
magician59
#2 Posted : Tuesday, February 10, 2009 1:04:05 PM(UTC)
magician59
Could be a bad power transformer. You can perform continuity and resistance checks on the secondary windings, but it takes a very expensive and specialized meter to do voltage checks-VERY HIGH VOLTAGE. You must use extreme care.
TOPPSAUTO
#3 Posted : Wednesday, February 11, 2009 9:26:07 AM(UTC)
TOPPSAUTO
If the diode is the incorrect replacement will this cause the capacitor not to charge at all? The original diode showed had no ohm readings in either direction. When replaced the capacitor still would not charge. Also when trying to match up a HV transformer which numbers do I need to check for correct replacement?
thanks, Steve
magician59
#4 Posted : Wednesday, February 11, 2009 9:49:05 AM(UTC)
magician59
These diodes sometimes need an additional voltage applied to test with your ohm meter. If you don't get a reading, it doesn't necessarily indicate a bad diode. If the capacitor isn't charging, and yu replaced it with another one that isn't charging, chances are very good that the culprit is the HV Transformer. By the way, if you're replacing the diode, the arrow on the body (schematic symbol) points to chassis ground.
TOPPSAUTO
#5 Posted : Wednesday, February 18, 2009 3:59:26 AM(UTC)
TOPPSAUTO
what numbers on the hv transformer do I need to be concerned with when trying to match up a new transformer for compatablilty
magician59
#6 Posted : Wednesday, February 18, 2009 4:44:08 AM(UTC)
magician59
Input voltage, output voltage (if printed on xfrmr), wattage.
Guest (5)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Change Microwave Bulb (Microwave Repair)
by Guest 6/20/2022 7:26:07 AM(UTC)
GE Microwave Lighting Issue (Microwave Repair)
by HDL 5/5/2022 11:29:53 AM(UTC)
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 10/19/2021 12:38:16 PM(UTC)
GE Microwave Not turning table nor heating JVM1540DM4WW (Microwave Repair)
by gnieciag 7/14/2021 6:33:35 PM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Samsung Over-the-Range Microwave (Microwave Repair)
by smitty121064 2/11/2021 8:14:40 AM(UTC)
GE Microwave tripping breaker (Microwave Repair)
by Bafire0731 2/21/2019 3:08:47 PM(UTC)
ge microwave door (Microwave Repair)
by david habenicht 10/29/2018 11:26:32 PM(UTC)
Samsung over range microwave no power (Microwave Repair)
by toolmaker129 10/25/2018 10:03:29 AM(UTC)
GE Microwave Not Heating (Microwave Repair)
by JIMMIEM 2/3/2018 6:14:54 AM(UTC)
GE microwave exhuast fan won't shut off (Microwave Repair)
by diy_dave54 9/21/2017 7:55:08 AM(UTC)
GE Microwave Start and Quick Start Buttons Don't Work. (Microwave Repair)
by garypatterson 5/15/2017 10:47:49 AM(UTC)
GE Microwave - dead (Microwave Repair)
by bfamily 3/5/2017 2:32:33 PM(UTC)
