markdeveer@gmail.com
#1 Posted : Friday, December 23, 2011 9:36:52 AM(UTC)
Gas dryer runs, but no heat. Cleaned all air vents, replaced both thermostats, ignitor & both solenoid coils. I'm getting 120 volts across the thermal fuse but no volts to the ignitor or the flame sensor.
Any suggestions would be appreciated.
ApplianceJunk
#2 Posted : Friday, December 23, 2011 9:39:32 AM(UTC)
ApplianceJunk
If you are putting a test lead from your volt meter on each terminal of the thermal fuse you should not read any voltage unless the fuse is bad.
Sounds like the thermal fuse is open and needs to be replaced.
If the thermal fuse is bad on this gas dryer it kills voltage to the ignitor, but not the rest of the dryer.
#3 Posted : Saturday, December 24, 2011 6:09:51 AM(UTC)
Thanks! That did the trick!
ApplianceJunk
#4 Posted : Saturday, December 24, 2011 6:13:52 AM(UTC)
ApplianceJunk
Your welcome,
Glad I coud help.
thanks for the update.
Guest (5)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 2/5/2014 5:57:38 AM(UTC)
Signature Gas Dryer Won't Heat (Dryer Repair)
by jsellnow 1/24/2014 9:10:42 AM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
Whirlpool Gas Dryer Won't Heat (Dryer Repair)
by jonellem 2/3/2013 7:27:46 PM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
by Clueless2 5/30/2012 9:02:40 AM(UTC)
by ejohnso6 4/21/2012 7:30:36 AM(UTC)
by sunshine2 5/19/2011 8:06:36 AM(UTC)
GE gas dryer won't heat (Dryer Repair)
by deadmusk 1/15/2011 11:27:35 AM(UTC)
Brand New Gas Dryer Won't Heat (Dryer Repair)
by AMLove 12/19/2010 3:47:49 AM(UTC)
by TimMN 11/17/2010 7:24:21 PM(UTC)
by ikohn 11/14/2010 3:40:40 PM(UTC)
by scolmery 10/27/2010 6:35:31 PM(UTC)
