Scout 1
#1 Posted : Friday, December 16, 2011 12:02:42 PM(UTC)
Scout 1
This machine has been making a raspy noise but would work through every cycle. Now, it failed in spin cycle. Pump worked and no spin.
Joe / APP Team
#2 Posted : Friday, December 16, 2011 12:41:23 PM(UTC)
Joe / APP Team
Scout,
Your first check needs to be at the thrust bearing, drive pulley and belt under the bottom of the washer,
Part number: AP4009132
Part number: AP4024823
If the pulley cam or bearing assembly are worn or distorted, the washer will make a noise, and eventually start to slip because the tolerance changes, won't allow the brake rotor and stator to lock and unlock properly.
Good Luck and Thanks,
fills/drains, but wands don't spin, bad motor/pump (Dishwasher Repair)
by jpromee 11/7/2011 8:45:24 AM(UTC)
Spray arms don't spin/hard water build up (Dishwasher Repair)
by rzq6c8 2/20/2011 4:29:09 PM(UTC)
Maytag mdb6600 spray arms don't spin (Dishwasher Repair)
by starbase1999 12/11/2010 7:43:55 PM(UTC)
Lots of water spraying from arms, but they don't spin (Dishwasher Repair)
by rjs.napc 12/1/2009 5:30:42 PM(UTC)
Washer don't spin (Washer Repair)
by cdodge 10/14/2009 8:55:05 AM(UTC)
washer don't spin (Washer Repair)
by jbrunetquixtar 7/4/2009 5:40:58 AM(UTC)
Maytag don't spin right (Washer Repair)
by wvhemi 6/6/2009 4:10:06 PM(UTC)
whirpool don't spin (Washer Repair)
by handyman68 5/23/2009 10:00:30 AM(UTC)
by caper 3/2/2009 8:36:51 AM(UTC)
Bosch Dishwasher Spay Arms Don't Spin (Dishwasher Repair)
by RBSOBAY 2/9/2009 6:16:36 PM(UTC)
Motor humming and water comes but blades don't spin (water pressure problem?) (Dishwasher Repair)
by mtheriault3 1/4/2009 10:13:31 AM(UTC)
Washer arms don't spin (Dishwasher Repair)
by gewoz 1/21/2008 4:01:59 PM(UTC)
