5 Pages<1234>»
magician59
#11 Posted : Tuesday, December 13, 2011 10:15:09 AM(UTC)
magician59
Rank:: Advanced Member
Do you get a reading across the two wires when you close the start switch?
frank the tank
#12 Posted : Tuesday, December 13, 2011 10:34:33 AM(UTC)
frank the tank
just checked again. With both wires off I get a reading weather on or off,, Where to next..
magician59
#13 Posted : Tuesday, December 13, 2011 10:47:44 AM(UTC)
magician59
I'm stumped.
frank the tank
#14 Posted : Tuesday, December 13, 2011 10:49:10 AM(UTC)
frank the tank
to clarify, i took the wires off the switch and weather I turn the start to on or off I get a reading.
Hey thanks for the time and help by the way. Im going on 3 hrs and have done all I could do.
frank the tank
#15 Posted : Tuesday, December 13, 2011 10:51:37 AM(UTC)
frank the tank
stumped doesnt sound promising... guess Ill have someone come out. shame only about 2 years old
#16 Posted : Tuesday, December 13, 2011 2:17:45 PM(UTC)
Hi Frank,
You probably overlooked something or did some test wrong.
Can you describe step by step how did you check the start switch (#14 on the diagram UserPostedImage), the proper alignment of the pedal, the top limit directional switch and it's alignment please?
frank the tank
#17 Posted : Tuesday, December 13, 2011 2:40:41 PM(UTC)
frank the tank
I'm at work at the moment gene. But i followed the troubleshooting instructions as outlined in the repair paper attached to tue unit. Only thing I'm not really sure how to check for alignment. It appears the metal tab on the upper limit switch appears to be engaged as the Compactor is in the up position. The pedal seems ok. I checked to make sure the metal tab is not depressing the start button constantly.
I'm sure I must be nssing something.
#18 Posted : Tuesday, December 13, 2011 2:48:50 PM(UTC)
How did you run the continuity tests? Did you remove the wires from a device being tested?
frank the tank
#19 Posted : Tuesday, December 13, 2011 2:54:17 PM(UTC)
frank the tank
I'm pretty sure i did but will rerun tests again tomorrow. I know I checked the wires as well.
frank the tank
#20 Posted : Wednesday, December 14, 2011 7:33:38 AM(UTC)
frank the tank
#14 was rechecked with wires off. I get a reading then when button is depressed reading is no more...
Guest (4)
5 Pages<1234>»
