AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
my maytag dishwasher wont spray water with any significant pressure
my dishwasher wont spray water with any significant pressure to wash dishes.This problem is recent. I rigged the switch to see inside the dishwasher while running and here is what its doin..It drains fine, and it gets the water supply ok but when the cycle starts, the water pressure is fine for about 5 seconds then quickly dies down to a trickle.. The motor is running and it is draining fine....what could be the problem...please help
Your model may have a filter/screen inside that needs to be cleaned. quiet series 300 is not the model number I need to look up a diagram. Please post the full model number that is on the model/serial number tag that can be found on the dishwasher.
Originally Posted by: ApplianceJunk  Hi,
Your model may have a filter/screen inside that needs to be cleaned. quiet series 300 is not the model number I need to look up a diagram. Please post the full model number that is on the model/serial number tag that can be found on the dishwasher. Sorry bud..The model # is--mdb7600aww Serial # is--23710434en thank you for ur assistance
ok..I have that #7 pump filter in my hand..On top of it there are some particles of sediment/deposits but i have no way to check inside it..How do I check it to make sure it is good or bad.. and once again, thank you for your assistance:)
Dishwasher Repair
