nailznine
#1 Posted : Monday, December 12, 2011 4:46:19 PM(UTC)
nailznine
my dishwasher wont spray water with any significant pressure to wash dishes.This problem is recent. I rigged the switch to see inside the dishwasher while running and here is what its doin..It drains fine, and it gets the water supply ok but when the cycle starts, the water pressure is fine for about 5 seconds then quickly dies down to a trickle.. The motor is running and it is draining fine....what could be the problem...please help
ApplianceJunk
#2 Posted : Monday, December 12, 2011 4:57:38 PM(UTC)
ApplianceJunk
Your model may have a filter/screen inside that needs to be cleaned.
quiet series 300 is not the model number I need to look up a diagram.
Please post the full model number that is on the model/serial number tag that can be found on the dishwasher.
nailznine
#3 Posted : Monday, December 12, 2011 5:05:50 PM(UTC)
nailznine
Sorry bud..The model # is--mdb7600aww
Serial # is--23710434en
thank you for ur assistance
ApplianceJunk
#4 Posted : Monday, December 12, 2011 5:12:03 PM(UTC)
ApplianceJunk
Look at #7 pump filter in this diagram for your model dishwasher.
Pump & motor replacement parts for MAYTAG MDB7600AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Could be getting plugged up with hard water deposits.
nailznine
#5 Posted : Monday, December 12, 2011 5:29:56 PM(UTC)
nailznine
ok..I have that #7 pump filter in my hand..On top of it there are some particles of sediment/deposits but i have no way to check inside it..How do I check it to make sure it is good or bad.. and once again, thank you for your assistance:)
ApplianceJunk
#6 Posted : Monday, December 12, 2011 5:50:46 PM(UTC)
ApplianceJunk
Here is the service manual for your model dishwasher.
http://appliancejunk.com...ownloads;sa=view;down=83
It has some great troubleshooting information that you may find helpful.
On page 4-16 it talks about POOR WATER CIRCULATION.
