DNE
#1 Posted : Wednesday, February 11, 2009 3:54:33 PM(UTC)
DNE
My freezer had water under tonight when I got home from work. This has happened before, I blamed the kids for leaving door open. Well it happened again today. I had not voltage at compressor, the thermostat was calling (closed). I tapped the timer on the back of unit and it started. I thinking I have a bad timer. What do you think.............
DNE
#2 Posted : Thursday, February 12, 2009 2:57:55 AM(UTC)
Sounds like you found the problem
Did you notice if the fan in the freezer was running?
It is usually wired in parallel to the compressor, so if it was also off this raises the odds that you have the correct culprit.
DNE
#3 Posted : Thursday, February 12, 2009 8:18:18 AM(UTC)
DNE
thanks for the reply
no the fan was not running and did not have voltage to it, the defrost element was not hot, but when i tapped the timer unit came on. I checked temp this morn and it was 10, seems to work fine now. This is 2nd time this happened, I cant trust this freezer.
dne
#4 Posted : Thursday, February 12, 2009 8:31:11 AM(UTC)
Well worth investing in a new timer at approx $16.00.
http://www.appliancepartspros.c...13&diagram_id=335228
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
