ok dryer has absoutley no heat ,i replaced the coils the thermostats seem to be fine, the sensor gives me a reading and the ignitor works as well, though it only glows for about ten seconds than cuts off is this normal? know thee only things i have left to check are the thermo-fuse and the heating now are there any another elements i have to check for, or are these five main parts associated with the no heat to dryer
If there is nothing wrong with these five parts and the gas line is open then the problem is the gas safety valve. There is no way to test it. - The part number for the gas safety valve is AP2043480Gene.
gene if the ignitor gives me a reading can it still be bad? I'm asking only cause I was told this and just wanted to verify, also the 4wire thermostat part number ap2044414 when i tested it, i put one end of the multimeter on the left element and the other end on the far right element and got a reading, but when i tested the the two middle elements i got a reading but it said it was bad am i doing something wrong or is thermostat bad
I'm not sure how to test this thermostat. You have to check the wiring diagram. If the igniter continuity test shows the closed circuit then it's good.
